Hi Brad
Thanks for your response. Actually I don't recall trying the older drivers - I just assumed I'd need the W7 64 bit drivers for this OS. Maybe some more testing will prove if there is any advantage, such as in speed of transfer or reliability perhaps.
Where I did have a problem initially was with a program I wrote for the kflop using Visual Basic .net. When I compiled for "any CPU" or "x64" the program refused to work. At first I suspected it was because the kmotion dll's were 32bit and not compatible - since the error message pointed to this.
But then I stumbled on some online discussion that indicated I should try compiling for X86 CPU - and lo and behold it then worked. Apparently if Win7 X64 sees a program which is compiled as X64 it expects the dll's to also be x64. But if you compile for X86 then it forces the OS to recognise them as 32 bit...
BTW I notice you are writing some interface for C#. I'm curious if
this offers significant advantages working with Kflop? Is it because you get more direct control of the internal functions this way? With VB.net I am restricted to the command set used by the kmotion console in combination with user c programs in the kflop.
Regards Gerald Thompson
--- In
DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@...> wrote:
> I have not checked the version, but I am able to run the default download on my win7x64 machine with no issues.
> I am interested to hear specifics on the problems you encountered in case they arise in the future.
> -Brad Murry
